- Thank you received: 33
Fuel and vacuum lines
- nickleo373
22 May 2013 00:27 #588660
by nickleo373
Hello Everyone
I recently bought a 1981 KZ550 LTD. The previous owner took the fuel and vacuum lines off of the bike except for the one in the attached picture. I was wondering if this is the correct placement of this line and it would be appreciated if anyone had a picture of the rest of the fuel and vacuum lines attached to a carb for reference.
Thanks
Nick
1981 KZ550C LTD
"If you ain't first, you're last"
Fuel and vacuum lines was created by nickleo373
Attachment gasline.jpg not found
Hello Everyone
Thanks
Nick
1981 KZ550C LTD
- Motor Head
- Thank you received: 391
22 May 2013 09:54 #588714
by Motor Head
No. That is actually the fuel line that is attached at the Carb Tee fitting. It is supposed to go to the petcock not the Engine Breather. The Engine Breather would hook to the Airbox, unless you have Pod's. Then a small filter would attach there.
You need a service manual. Member Loudhvx maintains a site for the 550's, and has a free pdf of a factory service manual, along with LOTs of other info. home.comcast.net/~loudgpz/GPZweb/Mnls/Mnls.html
Replied by Motor Head on topic Fuel and vacuum lines
Hello Everyone
Thanks
Nick
- nickleo373
22 May 2013 16:59 #588780
by nickleo373
1981 KZ550C LTD
Replied by nickleo373 on topic Fuel and vacuum lines
Ahh thanks a lot. I don't know why the guy put it there :huh:
1981 KZ550C LTD
