- Thank you received: 2
Fuel line nightmare/ how to?
- recez
- 74 kz400 D
19 May 2013 21:14 #588237
by recez
74 kz400 D cafe
Fuel line nightmare/ how to? was created by recez
This is sort of a silly question.. but I need to ask to make sure I'm doing this right. The thing I dread most when taking off my carbs or checking my electrical connections is taking off the fuel tank. The reason being is that It's so hard for me to pull my fuel lines from the carbs, petcock, or inline filters. Just yesterday I pulled the fuel line from the petcock and the actual nipple from the petcock came out still connected to the hose. I'm not draining the carbs before doing this so I don't know if that will change anything... but gezz getting these hoses off is really the hardest thing for me... Sometimes it feels like there has to be an easier way than just pulling them until they break loose... this take a lot of force. I did see an quick connect adapter from Dime City but I couldn't use this with the inline filter on the left side...as there is not enough room for both the filter and the adapter (length wise). Any suggestions on how to make this less of a brute force job and more of a finesse job? I really hate doing it. I'm going to break something else if I don't figure out a better way.
74 kz400 D cafe
- Powerstroke_fan
- Thank you received: 83
19 May 2013 22:23 #588243
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Fuel line nightmare/ how to?
I always take a pair of pliers and lightly twist the line so it actually unsticks from the nipple and it allows it to be pulled off easier.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- recez
- 74 kz400 D
19 May 2013 22:55 #588247
by recez
thanks for the tip... I'll give that a try and see if it helps.
74 kz400 D cafe
Replied by recez on topic Fuel line nightmare/ how to?
Powerstroke_fan wrote: I always take a pair of pliers and lightly twist the line so it actually unsticks from the nipple and it allows it to be pulled off easier.
74 kz400 D cafe
- Thank you received: 2098
20 May 2013 00:17 #588277
by Patton
Replied by Patton on topic Fuel line nightmare/ how to?
A pair of long reach 45° needle nose pliers works for me.
A better grade of fuel line may last longer before hardening up.
- recez
- 74 kz400 D
20 May 2013 01:02 #588288
by recez
thanks Patton... I'll put those on my list.
74 kz400 D cafe
Patton wrote: A pair of long reach 45° needle nose pliers works for me.
74 kz400 D cafe
