750e carb into 650
- Cajun
19 May 2013 20:21 #588229
by Cajun
1978 KZ650 D1
750e carb into 650 was created by Cajun
Would it be beneficial to put the carburetor from a 750E that has k&n filters into my 78 650D? Or would it be the same?
1978 KZ650 D1
- recez
- 74 kz400 D
- Thank you received: 2
20 May 2013 01:57 #588292
by recez
74 kz400 D cafe
Replied by recez on topic 750e carb into 650
I'm like the worst person to chime in on this question, as I've just recently got my own bike to run and was my first time doing so. . Wouldn't it produce an overly rich running condition which the pods would help lean out but maybe not enough to compensate for the carbs design? This may be way off, But just wanted to throw in my thoughts, if someone could correct me if I'm wrong then we'll both be wiser KZ'ers. Here to learn... here to help. I would think larger engine means more fuel therefore, too much fuel not enough air for the smaller 650?
74 kz400 D cafe
The following user(s) said Thank You: Cajun
- Cajun
20 May 2013 08:11 #588303
by Cajun
1978 KZ650 D1
Replied by Cajun on topic 750e carb into 650
I considered the same, but looking at the design with the K&n filters I also thought that it might get a little more air
1978 KZ650 D1
- recez
- 74 kz400 D
20 May 2013 13:51 #588352
by recez
74 kz400 D cafe
well hey, if they'll fit into the intake boots give it a shot and see what happens. It seems that the only real damage an overly rich condition will cause is fouling out the plugs. Better that way than on the lean side. See where it goes Maybe?
74 kz400 D cafe
