VENT BOWL
- stroker220
17 May 2013 17:03 #587960
by stroker220
VENT BOWL was created by stroker220
have 1973 later 28mm carbs just cleaned and set fuel pouring out vent in bowl...
- Thank you received: 2237
19 May 2013 02:25 - 19 May 2013 02:26 #588149
by TexasKZ
Replied by TexasKZ on topic VENT BOWL
Needle and seat valve failure
Incorrect float height
Broken vent tube
Broken vent tube
Last edit: 19 May 2013 02:26 by TexasKZ.
- Thank you received: 2098
19 May 2013 10:02 - 19 May 2013 10:05 #588165
by Patton
Replied by Patton on topic VENT BOWL
Which carb(s) is/are overflowing?
Sometimes helps to rap smartly and repeatedly against the float bowl with a plastic mallet or large screwdriver handle while the engine is idling -- and might see that gasoline stops discharging from the overflow hose.
And of course, an aftermarket in-line fuel filter was fitted into each fuel line before any gasoline was allowed into the freshly cleaned carbs.
Last edit: 19 May 2013 10:05 by Patton.
