Mikuni 34mm
- mopguy
Mikuni 34mm
16 May 2013 19:46
I have a 1981 KZ1000 carburetor that I need to set the float bowls to proper height, does anybody know the proper height?
- jonarmstrong
Re: Mikuni 34mm
16 May 2013 21:27
Everyone says to set them by the clear tube test. Gas level should be 3mm +/- from mating surface of bowl
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
Re: Mikuni 34mm
16 May 2013 21:34
The correct way to set the fuel height is with the clear tube method. There are several threads with tutorials on this site and the procedure is described int the factory shop manual. If you want a free copy of the manual, pm me your email address and I'll send you a copy. The float height measurement is only to get things in the ballpark prior to doing the clear tube method.
Re: Mikuni 34mm
16 May 2013 22:40TexasKZ wrote: The correct way to set the fuel height is with the clear tube method. There are several threads with tutorials on this site and the procedure is described int the factory shop manual. If you want a free copy of the manual, pm me your email address and I'll send you a copy. The float height measurement is only to get things in the ballpark prior to doing the clear tube method.
+1 The clear tube method is the only accurate way to set fuel levels. Ed
- Motor Head
Re: Mikuni 34mm
16 May 2013 23:15mopguy wrote: I have a 1981 KZ1000 carburetor that I need to set the float bowls to proper height, does anybody know the proper height?
Everyone has answered correctly, but missing your original questions answer. So check the service manual in my signature it will have the BS34 carbs in it. It will tell you both the Dry Height adjustment, as well as the Clear Tube test dimension.
- mopguy
Re: Mikuni 34mm
16 May 2013 23:16
Thanks Ed, my engine was racing at 6000 rpm when I started it, I took carbs boots off and found number two full of carbon deposits, looks like a vacuum leak,cleaned them all good, put gasket sealer on boots and re attached them all, float height vary from carb to carb using clear tube method, level are all different,not much, but different. How high should they go up?
- mopguy
Re: Mikuni 34mm
16 May 2013 23:25
Motorhead I am still a newby here when it comes to terminology. what do you mean by check my signature? Sorry for the incompetence.
- Motor Head
Re: Mikuni 34mm
16 May 2013 23:29
pdf version of KZ1000 service manual, for download. You need a pdf reader such as Adobe Acrobat Reader.
- mopguy
Re: Mikuni 34mm
16 May 2013 23:40
Thanks a lot for service manual, learning something new everyday. God bless KZR.
- mopguy
Re: Mikuni 34mm
24 May 2013 16:21 - 25 May 2013 19:34
Set float according to service manual 18.6 mm and gas overflows out of air intake, looked at another site and said dry float height to be set at 22.6 mm + or - 1 mm, I did that and still not getting gas to pistons,lowered float to 21.6 mm and still not firing,did clear tube test and looks to be just a tad below gasket level, put some wd-40 in pistons and she fired up with no pods on and started with a racing idle (5000 rpm), put pods on gave throtle and rpm went down to 1200 and when I gave it throthle again she wasnt responding well, rpm would not go past 4000, and finally she died. Now she doesnt start due to no fuel going to pistons, should I lower float even more, or raise it. Could there be another issue I am missing. Forgot to mention, sparkplugs were full of carbon and air/fuel screws turned to 2 1/2 turns.
Last edit: 25 May 2013 19:34 by mopguy. Reason: better wording
- mopguy
Re: Mikuni 34mm
31 May 2013 22:12
Okay, so nobody can help me yet, however I was looking at the BS34mm rebiuld tutorial and saw in the pictures of a slide with the diaphgram at the bottom and jet needle at the top,that means jet needle is fastened in the slide, mine is just placed in there, if you turn slide upside down, the needle falls out. Question is, are the needles fastened to the slides in this carburetor, because if they are, I am missing the pieces to fasten the needle, and that means the previous owner was in here, and probably why I am having difficulties, also if I spray carb cleaner in from main jet where should the cleaner come out?.
- peter1958
Re: Mikuni 34mm
31 May 2013 22:46
IF YOU SET THEM TO 28.6 AND THERE STILL OVERFLOWING TAKE A LOOK AT YOUR PETCOCK.
www.kzzone.com/
