'75 Z1 petcock
- Stev-o
Guessing this is not stock and if so, why would the PO do it.
The bike runs great so no causing an issue, I'm just curious and want to bring back to stock.
Thanks
'75 Z1 '74 H1 '74 H2 basket case ..... plus plus plus...
- Thank you received: 2829
Attachment 000000.jpg not found
- Stev-o
Z guys - do you have two fuel lines??
- Stev-o
650ed wrote: Maybe a P.O. swapped out the carbs. Ed
Yeah, was thinking that too. Need a Z guru to confirm.
Thanks Ed
- Thank you received: 2098
It's common for one petcock outlet nipple to be capped off when replacing the stock dual hose carbs with single hose carbs such as smoothbores for example.
- Stev-o
Patton wrote: kawasaki.com shows "75 Z1-B with two fuel hoses, and two tee style fuel pipes.
Thanks for the info. So, sounds like I may not have stock carbs, would not surprise me. Smoothbores would be sweet! The bike is very fast! Seems much faster than my Honda CB836 [750 bored out]
I'll snap some pics.
Thanks guys.
Click here > www.z1enterprises.com/Z1CarbGuide.aspx
Each carb image may be clicked for a large view.
Appears that the stock carbs for Z1's and KZ900 have dual fuel hoses.
- Dr. Gamma
- Thank you received: 681
Z1 Enterprises shows what I am talking about on their LH picture of the 29mm Smoothbore carbs. Thats how I could tell if the KZ had 29mm Smoothbores on it!!!!
1986 RG500G 2 stroke terror.
Dr. Gamma wrote: The best way and the quickest way to tell if you have 29mm Smoothbores is look for the little cast in square box with a round end of a piece of brass on the outside of #4 carb. That square box is right above the raised area of where the bowl mounts to carb body. The rubber piece on the kickstarter covers up this marking on #4 carb. Just unfold the kickstarter and look for that marking.
See circle in pic....
Attachment 00000x.jpg not found
- Stev-o
The number 1 carb states MIC, I know that is Mikuni. What are these??
Guessing the carbs at hand are 26mm from '77 or '78 KZ1000, evidenced by having bottom-located pilot mixture screws.
The '76 KZ900 also has 26mm, but with side-located pilot air screws.
The '78 and '79 KZ1000 cafe racers, and '79 KZ1000 Mark II, have 28mm with side-located pilot air screws.
