- Thank you received: 1
Fuel Leak
- BIGKEVIN
14 May 2013 13:45 #587363
by BIGKEVIN
1976 KZ900
2006 ZX6R
Fuel Leak was created by BIGKEVIN
I started up my 1976 KZ900 with 29 mm Mikuni carbs today and took it for a quick ride. When I got back I noticed that there was fluid leaking under the bike. I checked it and it was fuel leaking from the T and the #3 carb. I suspect that there is a rubber gasket there ? Does anyone have any instructions on the correct way to take the carbs apart to check this ? Thanks in advance.
1976 KZ900
2006 ZX6R
- BIGKEVIN
15 May 2013 21:28 #587600
by BIGKEVIN
1976 KZ900
2006 ZX6R
Replied by BIGKEVIN on topic Fuel Leak
I got the carbs apart and got the T connector out. One of the rubber gaskets was broken. I don't see a replacement T at Z1 Enterprises, but I see that they do sell gaskets, but I am not sure what size gasket is for the 29 MM carbs. Anyone have any idea where I can get another T or the gaskets ? Thanks.
1976 KZ900
2006 ZX6R
- Motor Head
- Thank you received: 391
15 May 2013 22:57 #587629
by Motor Head
Replied by Motor Head on topic Fuel Leak
I think you might have missed the parts at Z1, as they have the fuel Tee and o-rings/ gaskets for the 29's.
www.z1enterprises.com/ItemDetails.aspx?i...hbore&item=ZSM26-269
As always, its worth asking the guys there for a part or help finding a part.
- BIGKEVIN
16 May 2013 20:26 #587806
by BIGKEVIN
1976 KZ900
2006 ZX6R
Thanks Motor Head. I did miss that. I have ordered the parts.
1976 KZ900
2006 ZX6R
