Syncing Carbs
- Brian.Wolf
13 May 2013 10:01 #587142
by Brian.Wolf
Syncing Carbs was created by Brian.Wolf
I have a 1981 kz 750 BUT i have kz1000 carbs on it. Im not sure what year or model but i know one of the adjustment screws are on top of the carb on motor side and the top of the carb is more a a circle shape than the long and narrow one. Im just wanting to know how to sync them. Help me please. im so confused
- KZQ
- Administrator
- Thank you received: 1415
13 May 2013 10:32 #587144
by KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Replied by KZQ on topic Syncing Carbs
Hi Brian,
Welcome to KZR.
I'm pretty sure that you're describing constant velocity carbs "...the top of the carb is more a a circle shape than the long and narrow one..." Pics would help. How do you know you have kz1000 carbs? Do you know the year?
Bill
Welcome to KZR.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- baldy110
- Thank you received: 512
13 May 2013 12:04 #587154
by baldy110
Replied by baldy110 on topic Syncing Carbs
What you have should be the Mikuni BS34 CV carbs. To synch them you need special equipment. It is really not that hard once you have the correct equipment. What makes you think they need to be synched?
- Brian.Wolf
13 May 2013 12:36 #587163
by Brian.Wolf
Replied by Brian.Wolf on topic Syncing Carbs
The bike runs just not just not very well and bogs down when given throttle. 2 of the spark plugs keep fouling out and two seem fine. After about 30 seconds of running the #2 and #3 exaust isnt hot like the other ones. i can touch them but the other ones are really hot. I cleaned the carbs twice but i still cant get the thing to run right. I can post pictures later today if you think you can help . Thanks
- Brian.Wolf
13 May 2013 13:38 #587180
by Brian.Wolf
what the bike does is it will start but idle really high at first then come down to a really low idle and run really rough i think only on 2 cyclendres and as soon as i give it any gas at all it dies. whats the problems ?
- baldy110
13 May 2013 13:52 #587183
by baldy110
Has the bike ever ran good with these carbs, if so when did they start doing this?
- Brian.Wolf
13 May 2013 14:38 #587188
by Brian.Wolf
yes they did but then they sat awhile and i swtiched motors.
- Thank you received: 2098
13 May 2013 15:34 #587199
by Patton
Replied by Patton on topic Syncing Carbs
What's spark quality on #2/3 plugs?
- bluezbike
- Thank you received: 104
13 May 2013 16:27 #587206
by bluezbike
79 KZ 1000 LTD
Replied by bluezbike on topic Syncing Carbs
When you switched motors were they the same size/type (ie. both 750's) and did you check valve clearances especially on the 2 + 3 cylinders on the current motor?
79 KZ 1000 LTD
- Brian.Wolf
14 May 2013 12:23 #587346
by Brian.Wolf
no and i have no clue on how to check valve clearance. I dont even know where to start
- Thank you received: 2829
14 May 2013 12:32 #587351
by 650ed
Replied by 650ed on topic Syncing Carbs
You really should invest in a Kawasaki Service Manual. No owner of a KZ should be without one. They usually are available on eBay, just be sure to get one for your exact year/model bike as there are differences. Ed
- bluezbike
14 May 2013 17:35 #587413
by bluezbike
79 KZ 1000 LTD
+1 on what 650 Ed says, also make sure it is a Factory Service Manual and not a Clymer as there are a few key booboos to avoid. Next thing to buy is a good set of feeler guages (I prefer metric ones as it is a metric bike) Napa sells them for about $12. Then search in the engine section on valve clearance to get some idea of how and certainly why it needs to be done. And have fun
79 KZ 1000 LTD
