Need to remove the Carbs. I think.
- Ghostryder78
12 May 2013 20:39 #587069
by Ghostryder78
Need to remove the Carbs. I think. was created by Ghostryder78
I just purchased a 1982 KZ750. The shop I bought it from said they had the bike running the summer before, but that the carbs needed cleaned. The bike turns over, but I can't get it to start. The other idea is that the there is a problem somewhere with the spark plugs. I replaced all 4 spark plugs already. Any ideas or suggestions would be awesome. If someone could tell me the easiest way to remove the carbs that would be great as well.
- Thank you received: 2829
12 May 2013 21:36 #587078
by 650ed
Replied by 650ed on topic Need to remove the Carbs. I think.
Before removing the carbs how about describing exactly what you are doing as you try to start the bike. If you do not use the correct procedure it will not start even if everything is perfect. Ed
