- Thank you received: 29
Keihin CV Carb overflow
- Del_Herring
11 May 2013 16:57 #586890
by Del_Herring
1983 KZ750-N2 Spectre
Keihin CV Carb overflow was created by Del_Herring
I'm working on getting the KZ750N going again, and we hooked it up to fuel today and fuel started dumping out the bottom drain on the carbs. I can't recall if these carbs have a seperate overflow circuit, or if they're the type that use the combo drain/overflow.
Just trying to track down this problem so I can get her back running again. I've got spark and she's cranking over good now, almost there.
- JR
- Thank you received: 449
11 May 2013 20:41 #586913
by JR
Replied by JR on topic Keihin CV Carb overflow
I'm pretty sure you have the same carbs as on my 1980 750 /4 so the overflows are the combo drain / overflow type.
Only a few reasons gas may be flowing out
Drain screws not closed ( unlikely)
Float needle valves dirty or worn
Brass overflow tubes cracked
Good luck
Good luck
The following user(s) said Thank You: Del_Herring
