- Thank you received: 2
carb holders 16065-1046 OH NO!
- johnjones750csr
08 May 2013 19:02 #586397
by johnjones750csr
carb holders 16065-1046 OH NO! was created by johnjones750csr
Oh no, I need carb holders and they are discontinued. This is not good, Z1 couldn't get them, and kawasaki has them discontinued, so ron ayers wont be able to get them either. Shit. Is there any others that will fit my 1982 CSR 750 Twin? I tried fixing them a couple of times and they hold for a couple months and start leaking again. I've tried like 4 kinds of sealant with no luck.
Thanks
Thanks
- Thank you received: 1656
08 May 2013 20:39 #586413
by martin_csr
Replied by martin_csr on topic carb holders 16065-1046 OH NO!
Perhaps bountyhunter or steell will chime in. If you don't get an answer here, try the KZ400.com site - ask in the 750-Twin sections. With any luck, perhaps the earlier carb holders can be used?
Also, try looking around the JBM Industries site - they make reproduction rubber parts for motorcycles.
- boatdrinks
- Thank you received: 54
08 May 2013 22:04 #586433
by boatdrinks
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
Replied by boatdrinks on topic carb holders 16065-1046 OH NO!
Probably a long shot but give them a call.
www.dealercostparts.com/pages/OemParts?a...50-H1-1981/070087B-4
Charles
Madison, AL
- boatdrinks
08 May 2013 22:38 #586454
by boatdrinks
Charles
Madison, AL
oops sorry, thought you had a 650.
Charles
Madison, AL
- loudhvx
- Thank you received: 1616
09 May 2013 10:44 #586555
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic carb holders 16065-1046 OH NO!
If all else fails, you can always make a metal flange and connect with a section of hose. I've done that on a few 400's with success.
1981 KZ550 D1 gpz.
Other links.
The following user(s) said Thank You: nitrokrumpt
- Jeff.Saunders
09 May 2013 10:57 #586557
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic carb holders 16065-1046 OH NO!
Good idea Lou - I like the concept.
Z1 Ent on Facebook,
- Thank you received: 797
09 May 2013 11:10 #586562
by 531blackbanshee
Replied by 531blackbanshee on topic carb holders 16065-1046 OH NO!
here is the link for the site martin recommended.
jbmindustries.com/
it is possible to open up intakes that are too small by using a tool post grinder on the lathe.
nuthin drastic but a few mmm's isn't a problem.
jbmindustries.com/
- johnjones750csr
09 May 2013 19:16 #586621
by johnjones750csr
Replied by johnjones750csr on topic carb holders 16065-1046 OH NO!
I think I may have found a solution. Well two of them. I've been in contact with Z1 enterprises and they did some tape measurement on some carb holders that they have in stock. Turns out that the carb holders for a Yamaha XS400SG/SH/SJ 80-82 May fit.
The other solution that I came up with is underneith the rubber face of those carb holders is a metal plate. I sanded off all of the old messed up rubber down to bare metal with a rubber ring on the inside. Went and got some gasket material bulk from the parts store and made a new sealing surface for the boot. Used Seal-All on the boot to gasket surface and use a permatex non-rtv gasoline safe sealant that handles higher heat on the gasket to head surface. This Stuff I got hardens and doesn't stay guey like the blue stuff that I tried. I'll keep everyone posted.
