How to Disconnect Fuel Line(s)
- PaulyWally
- Total Bike Newbie
1976 KZ750 Twin
- lightitup
- Thank you received: 10
- MFolks
- Thank you received: 540
- loudhvx
- Thank you received: 1616
On fuel lines that you want to keep (black rubber tubing designed to handle modern fuel), if the hose is super tight on the pipe, I will use pliers and sort of pinch the tubing to release it from the pipe, then wiggle the hose off. Then maybe trim 1/4" off to have a fresh end.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- PaulyWally
- Total Bike Newbie
lightitup wrote: pull :evil:
I've been doing that... on every part of the hose. It seems the harder I pull, the more they grip the nipple on the tank valve.
I assume the in-line "barrel" connector has something to do with it... but I can't seem to figure that one out either.
MFolks wrote: If you're worried about fuel getting all over, before doing any gas line work, get some golf tee's. They are tapered and will stop the gas flow. I'd replace any plastic of rubber fuel lines too, as today's fuel for the most part contains Ethanol, that attacks rubber and plastic fuel lines.
I'm not worried about getting gas all over. I just can't get them off. And I think these are fairly new fuel lines. I bought the bike 18 months ago, and these are the newest-looking things on the bike.
1976 KZ750 Twin
- Thank you received: 2829
- PaulyWally
- Total Bike Newbie
650ed wrote: They do not look like fuel grade tubing to me. I would just cut them all off and replace them with real fuel line. Ed
Cool. Thanks! I guess that solves 2 problems! :woohoo:
1976 KZ750 Twin
- havakaw
- Thank you received: 27
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- havakaw
'80 KZ 750 LTD-H
