- Thank you received: 44
AIR BOX BOOT TIP!
- KraZyRIDER
05 May 2013 09:45 #585756
by KraZyRIDER
Mean Green Speed Machine!
1979 KZ 650-C3 (Cafe Project)
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
AIR BOX BOOT TIP! was created by KraZyRIDER
...Not sure if this has ever been mentioned before. But, here goes.
...If you ever run across hard air box boots that you think are trash and ready to be $#!+ canned. Or, are trying to remove your own and can't because they're too hard and won't cooperate. Well, DO NOT DESTROY THEM taking them off and DO NOT TOSS them afterwards. Instead, go get your Wife's, Mom's, or Sister's hair dryer and bathe those rock hard, stiff boots in HOT AIR.
...One at a time, thirty seconds or so of hot air will turn those rock hard, unforgiving air tunnels into nice soft pliable, easily removable and replaceable units. No need to trash, or replace them.
...You can even use this method with good soft boots. It will make the job of removal and replacement even easier. Of course you won't need as much heat with good boots, half the time will suffice. But, a blow dryer will definitely make the job easier either way.
...Give it a try if you haven't already. You'll be amazed!
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
The following user(s) said Thank You: bluej58, daveo
- dbc92s10
- Thank you received: 5
07 May 2013 20:49 #586216
by dbc92s10
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
Replied by dbc92s10 on topic AIR BOX BOOT TIP!
another good trick is to soak them in warm water
81 ltd1000
1135 mtc 10.5/1
38.6/32 p&p
APE k410 cams
84 gpz1100 trans
rs36 carbs
- coolio
- Thank you received: 1
22 May 2013 00:56 #588669
by coolio
Replied by coolio on topic AIR BOX BOOT TIP!
Great tip!!
Too bad I didn't read your post a few weeks ago...
I ended up cutting mine off with an exacto knife, then buying new ones from Z1...
Installing the new ones...I soaked them in warm water which made all the difference in getting them back on...
Thanks again,
Thanks again,
- KraZyRIDER
24 May 2013 23:15 #589078
by KraZyRIDER
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
Replied by KraZyRIDER on topic AIR BOX BOOT TIP!
...the amazing thing about the hot air is, you can even get rock hard rubber to soften up. You'd need to boil water to do that and likely end up burning your fingers trying to install them.
...plus, hot air has another big advantage over hot water. If the tubes start to cool and get stiff again during installation, just hit them with the hairdryer again while they're in place. With hot water, you'd need to remove them for another dip, or pour water on them in place. Not a very good idea.
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
The following user(s) said Thank You: bluezbike
