Fuel to carbs
- kledda970
04 May 2013 01:14 #585568
by kledda970
Fuel to carbs was created by kledda970
one of my carbs is not getting any fuel, thats why im thinking that it also stops after a block, its flooding....help plz
- Thank you received: 2829
04 May 2013 01:18 #585570
by 650ed
Replied by 650ed on topic Fuel to carbs
Please add your bike's year & model to your signature line. Different KZ models have different carb setups. Ed
- kledda970
04 May 2013 01:22 #585571
by kledda970
Replied by kledda970 on topic Fuel to carbs
kawasaki 1979 kz750t
- Thank you received: 2098
04 May 2013 01:42 #585574
by Patton
Replied by Patton on topic Fuel to carbs
:huh: Could the question be re-phrased to reconcile the inconsistency between "flooding" and "not getting any fuel"?kledda970 wrote: one of my carbs is not getting any fuel, thats why im thinking that it also stops after a block, its flooding....help plz
- kledda970
04 May 2013 04:51 #585577
by kledda970
im gussing the carbs are flooding because one of the carbs is not getting any fuel. so it just stops.
04 May 2013 09:42 - 04 May 2013 09:43 #585593
by 650ed
Does not compute. Flooding is a condition in which too much fuel is supplied and typically wets the spark plug and prevents it from firing properly. This condition cannot happen if there is no fuel going to the carb.
It might help if you describe in some detail exactly what happens from the time you start your bike until it stops running. Ed
kledda970 wrote: im gussing the carbs are flooding because one of the carbs is not getting any fuel. so it just stops.
Last edit: 04 May 2013 09:43 by 650ed.
- kledda970
04 May 2013 12:44 #585611
by kledda970
ok so every time i try to go down the block it will stop half way. and it won't start after. but if i let some gas out, which i do by unscrewing that one bolt by the carb, it will start again and go down the block half way, stop, wont start and i would have to repeat the whole letting out some gas thing.
