Carb only works when covered by my hand
  • kawtoy
  • kawtoy's Avatar Topic Author
01 Jul 2006 13:34
#58552
Just getting the bike running again after it sat for awhile. Cleaned the carbs and fresh gas. 1,2 and 4 ctlinders are running fine. #3 is not. If I cover the throat of the carb with my hand it will start to fire. If I totally cover it I get gas puring all over my hand. If I cover it and let just a bit of air in then it will run fine. What's up? Any ideas? I tried putting the pod on but it doesn't help. Thanks
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
  • ran429
  • ran429's Avatar
  • Master of FREE rides!
Re: Carb only works when covered by my hand
01 Jul 2006 14:04
#58555
my 900 750 did that, remove the diaphrams and all the jets again & blow them out after soaking in carb cleaner again.
take off the floats and make sure the feed input isnt plugged as well, and then run a fuel filter inline.
you most likely have a plugged fuel inlet.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
01 Jul 2006 18:39
#58602
One of your jets are plugged. By covering the intake you're cutting off the greatest part of the air flow and thereby compensating for the restricted fuel flow. Pretty easy fix, pull the jets and clean them.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • ambergrismooon
  • ambergrismooon's Avatar
01 Jul 2006 19:10
#58612
Easiest fix would be...
