- Thank you received: 5
Fuel Tank starting to leak..what to do
- NZGlenn
Funnily enough it is at the very bottom part of the tank, right where water will collect when it separates from the petrol,
Attachment 30042013622.jpg not found
all
1984 GPz1100A2
- NZGlenn
Attachment 30042013621.jpg not found
Attachment 30042013623.jpg not found
1984 GPz1100A2
- Thank you received: 2098
- NZGlenn
good point, i've just checked and unfortunately it is clean and dry under the tank and round the petcock. The tank is really bad with flaky rubbery stuff in it. The only good thing is the paint job.
I have another tank that is clean on the inside but has been hand painted (brush) by a previous person.
Question, Can you pressure test a tank if so how would you seal the fuel filler?
1984 GPz1100A2
Have never attempted to pressure-test a motorcycle fuel tank, but with the tank removed, would guess by closing the cap and removing the petcock, and introducing water from a household tap through a hose fitted snugly into the petcock hole (perhaps using a rubber grommet to help seal the where the hose enters the petcock hole), water could be seen escaping from inside the tank through a leak source.NZGlenn wrote: ...Question, Can you pressure test a tank if so how would you seal the fuel filler?
This method would not harm the tank's exterior paint finish.
- bluej58
- Thank you received: 511
www.grainger.com/Grainger/CHERNE-INDUSTR...lug-2HCF6?Pid=search
78 KZ1000 A2A
- Thank you received: 1656
- NZGlenn
1984 GPz1100A2
- TomW
- Keep the blue side up.
- Thank you received: 52
NZGlenn wrote: Thanks, all good ideas. I am going to try it and see what happens
If you get the tank rigged for a pressure test, keep the pressure LOW. 2 or 3 psi will be enough to find a leak with soapy water on the outside.
The flaky rubber stuff is probably a sealing compound that was used to stop the leak, maybe by a previous owner? It has failed. I see you have another tank. You just need a paint job.
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
The bathtub ought to do just fine. :lol:
- Motor Head
- Thank you received: 391
He hasn't had to re-do any of them, some were done quite a few years ago. The Ethanol crap doesn't seem to bother it, unlike some of the Tank Lines on the market. Of course proper application, cleaning etc is key to any of them.
Of course a good used tank is always best, if it isn't rusted also.
