Air Filter Woes
  • The_Proletariat
  • Topic Author
  • "Cocaine is a hell of a drug"
30 Apr 2013 00:32 #584815 by The_Proletariat
Air Filter Woes was created by The_Proletariat
Well I have a stupid question about my air filter.
1982 KZ550C3.
This is the exact filter I am trying to replace.
www.z1enterprises.com/ItemDetails.aspx?i...2900&item=EM12-92900
The box is clearly marked KZ550C.
I cannot get the top piece of the air box, the piece with two slotted screws to fit properly with this filter in the airbox. The air filter seems too large in almost every dimension to fit properly in the airbox.
1982 Kawasaki KZ550 LTD
  • Motor Head
30 Apr 2013 00:40 #584818 by Motor Head
Replied by Motor Head on topic Air Filter Woes
Is your bike a Canadian model? Kawasaki does have a different listing for the Canadian model, as to the US model. What the difference would be I don't know.
Does your old filter have a part # on it?
  • The_Proletariat
  • Topic Author
30 Apr 2013 00:56 - 30 Apr 2013 00:58 #584826 by The_Proletariat
Replied by The_Proletariat on topic Air Filter Woes
I am not sure. The speedometer is in mph. The old filter has been thrown away.
Last edit: 30 Apr 2013 00:58 by The_Proletariat.
30 Apr 2013 01:11 #584834 by drummerjoe10
Replied by drummerjoe10 on topic Air Filter Woes
check to see if the airbox has ever been changed, I ran into the same problem on my 750 csr and ended up someone had put a different airbox in. I have no idea what it came out of but it was never quite right until i changed it back to original, hope it helps.
Joe
30 Apr 2013 01:19 #584836 by Patton
Replied by Patton on topic Air Filter Woes
For reference (from kawasaki.com) --
Good Fortune! :)
  • The_Proletariat
  • Topic Author
30 Apr 2013 11:04 #584901 by The_Proletariat
Patton wrote: For reference (from kawasaki.com) --
Good Fortune! :)
Ya the filter is placed towards the front of the airbox. #11012 will not fit properly with the filter in the airbox.
30 Apr 2013 11:20 #584902 by 650ed
Replied by 650ed on topic Air Filter Woes
Assuming your airbox is the correct one for your bike, the genuine Kawasaki air filter is still available. If you contact Z1E and they can't help you may want to get one from the dealer.
Attachment 00000_2013-04-30.jpg not found
  • Motor Head
30 Apr 2013 11:31 #584904 by Motor Head
Its been a few years since I had the 80 550, but seems like there was a piece in the bottom of the airbox which the filter goes down and in front of. This holds the filter forward so the foam seals. Maybe I'm wrong but I seem to remember it having to go down in front of a Tab or raised area to get it in there.
  • The_Proletariat
  • Topic Author
30 Apr 2013 11:34 #584905 by The_Proletariat
650ed wrote: Assuming your airbox is the correct one for your bike, the genuine Kawasaki air filter is still available. If you contact Z1E and they can't help you may want to get one from the dealer.
The airbox is the right one. It is stamped KZ550A,C.
Just surprised this Z1 filter will not fit.
30 Apr 2013 12:09 #584909 by martin_csr
  • The_Proletariat
  • Topic Author
30 Apr 2013 12:19 #584911 by The_Proletariat
martin_csr wrote: Is this one the same as the one you got?
www.z1enterprises.com/ItemDetails.aspx?i...KZ550&item=BAHFA2504
No. The link in the OP is the filter I have.
  • The_Proletariat
  • Topic Author
02 May 2013 22:43 #585353 by The_Proletariat
Some pictures of what I am referring to. I cannot get this damn thing in the airbox properly.
[img
[img
[img
[img
