- Thank you received: 13
Air Filter Woes
- The_Proletariat
- "Cocaine is a hell of a drug"
1982 KZ550C3.
This is the exact filter I am trying to replace.
www.z1enterprises.com/ItemDetails.aspx?i...2900&item=EM12-92900
The box is clearly marked KZ550C.
I cannot get the top piece of the air box, the piece with two slotted screws to fit properly with this filter in the airbox. The air filter seems too large in almost every dimension to fit properly in the airbox.
1982 Kawasaki KZ550 LTD
- Motor Head
- Thank you received: 391
Does your old filter have a part # on it?
- The_Proletariat
- drummerjoe10
Joe
- Thank you received: 2098
- The_Proletariat
Patton wrote: For reference (from kawasaki.com) --
Ya the filter is placed towards the front of the airbox. #11012 will not fit properly with the filter in the airbox.
- Thank you received: 2829
Attachment 00000_2013-04-30.jpg not found
- Motor Head
- The_Proletariat
650ed wrote: Assuming your airbox is the correct one for your bike, the genuine Kawasaki air filter is still available. If you contact Z1E and they can't help you may want to get one from the dealer.
The airbox is the right one. It is stamped KZ550A,C.
Just surprised this Z1 filter will not fit.
- Thank you received: 1656
www.z1enterprises.com/ItemDetails.aspx?i...KZ550&item=BAHFA2504
- The_Proletariat
martin_csr wrote: Is this one the same as the one you got?
No. The link in the OP is the filter I have.
- The_Proletariat
