78 650 dropping 2 cylinders
- brademan76
Thanks for your any recommendations!
- Thank you received: 2829
- Thank you received: 2098
Could be an issue with spark quality (for whatever reason), or compression (valve clearances), or fuel mixture, or any combination of these.brademan76 wrote: While riding, 2 cylinders will randomly stop firing. Sometimes I can ride it out and they will just randomly kick back in... other times I'll have to shut down and restart, but even then it doesn't always start on all 4. I'm running pods and a 4-1 exhaust. Any ideas as to the cause? Does it sound more like a carb issue, or electrical? Thanks for your any recommendations!
To begin diagnosis --
Would perform the clear tube test on each carb;
Would remove the plugs and examine spark quality, looking for fat blue sparks;
Would assure valve clearances being within specs.
- brademan76
- MFolks
- Thank you received: 540
- brademan76
I swapped the coils and was still only firing on 1-4, so that tells me its not the coils. I pulled out plug 3 and fired the bike up and wasn't getting a spark at all. Could the dynatek unit itself be going bad or maybe its the wiring from the ignition system to the coil. I suppose I can check that with an ohmeter.
Thanks for the help.
- brademan76
www.kzrider.com/forum/2-engine/463907-kz...from-dyna-s-ignition
