engine cuts out
- jimray2300
29 Apr 2013 12:56 - 29 Apr 2013 13:00 #584654
by jimray2300
1979 kz1000b/ltd big cams, strait 4 - 1 full open exhaust, factory air box without the silencer, complete new wiring harness, rejetted carbs and hyway pegs.
engine cuts out was created by jimray2300
When im riding down the highway on my 79 kz1000 ltd and when i use my highway pegs, my bike acts like it is getting to much air or not enough fuel and starts bogging down, but if i move my feet back to the factory pegs it runs great. Does anyone know what could be the problem? By the way i am running the stock air box without the silencer.
Last edit: 29 Apr 2013 13:00 by jimray2300.
- baldy110
- Thank you received: 512
29 Apr 2013 14:01 #584663
by baldy110
Replied by baldy110 on topic engine cuts out
It is pretty simple really when you move your feet you are changing the airflow over the bike.
- jimray2300
29 Apr 2013 15:26 - 29 Apr 2013 15:28 #584685
by jimray2300
Replied by jimray2300 on topic engine cuts out
Yes but how can i stop the cut out so i can use the highway pegs. Sorry i should have been more specific
Last edit: 29 Apr 2013 15:28 by jimray2300.
- Thank you received: 2829
29 Apr 2013 16:27 #584686
by 650ed
Replied by 650ed on topic engine cuts out
As an experiment you may want to re-install the silencer to see if that improves the problem. Ed
- jimray2300
29 Apr 2013 16:29 #584687
by jimray2300
Thanks i will have to try to find one. The bike didnt have one when i got it
- baldy110
29 Apr 2013 17:13 #584694
by baldy110
Does this happen at steady throttle, is it bogging or surging? If it is at a steady throttle setting and it is bogging then it is running to rich in the midrange, raise the needle clip one spot. If it is surging then lower the needle clip one spot. Before I would do that however the easiest thing would be to do what 650ed suggested, find and put the silencer back in.
- jimray2300
29 Apr 2013 18:24 - 29 Apr 2013 18:31 #584713
by jimray2300
Yea its bogging at a steady throttle setting but only when the wind blows lol
Last edit: 29 Apr 2013 18:31 by jimray2300.
- jimray2300
29 Apr 2013 18:30 #584716
by jimray2300
Thank you both for all your help
