- Thank you received: 2
more help plz.....7000rpm miss
- natetru
pod filters
4-1 vance n hines
dyna coils
new plugs
bike runs good until i hit 7000 rpm then it starts to miss/run real rough. please help.....i am still very new to this bike and want to figure it out b4 i get frustrated and part ways.......help me....
1982 kz1000 m2 csr
- KZJOE900
- Admin
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- natetru
1982 kz1000 m2 csr
- Awjoyce
I have a 750 twin, and was having the same issue, not sure what your engine setup looks like, but mine has hoses coming from the airbox to the top of the head cover, which have a reed valve at the end that lets air into the exhaust port. Check to make sure that the reed valves are in the right way (with the reeds on the bottom so exhaust can't be fed back into the air box). Mine were upside down and once I flipped them, the issue went away.
Hope this helps, again, my engine's different than yours, but it's something to look at
I ride a 1982 KZ750 CSR M1 "Twin"
- natetru
1982 kz1000 m2 csr
- ironslave
- sup
1981 KZ750 LTD
- natetru
1982 kz1000 m2 csr
- natetru
1982 kz1000 m2 csr
- KZJOE900
- Admin
\natetru wrote: unrelated....i am chasing oil leaks.....everytime i change a leaking gasket and clean up my motro, i ride a day or 2 and then i have a new leak from a new place...i am getting frustrated.......anything that could cause
Which area are you getting leaks from? Not familiar with your model/year. Does your model use a mechanical tack cable? If so, it may be leaking from where the cable goes into the head. Also, I have been using Permatex Copper gasket spray after I saw some recommendations from other members that used it. So far I love the stuff. Used it on my old valve cover gasket, even though I had a new gasket available, just to see how well it would work. No leaks so far 6 months later. Also used on my oil pan and stator cover gaskets. No issues. But first you need to identify where the leak is coming from.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- natetru
1982 kz1000 m2 csr
- KZJOE900
- Admin
natetru wrote: already fixed leaks at base gasket,head gasket and tach seal.....now its leaking on right corner where the case splits........
Bummer! Had you split the cases in the recent past? If so should have used a bead of high quality black RTV sealer. Maybe you did so its leaking anyhow. I will leave advise on this topic to others with more experience.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Thank you received: 2098
One possibility --natetru wrote: unrelated....i am chasing oil leaks.....everytime i change a leaking gasket and clean up my motro, i ride a day or 2 and then i have a new leak from a new place...i am getting frustrated.......anything that could cause
