- Thank you received: 512
why the petcock should not be run on prime
- donthaveakawman
- Visitor
- baldy110
- jonarmstrong
- Thank you received: 13
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
- donthaveakawman
- Visitor
- Matteson
- Thank you received: 6
- donthaveakawman
- Visitor
- baldy110
donthaveakawman wrote: maybe if I had plugged the vacuum port it would have run smoother, in any case I richened the mixture via needle clip.
Now there is a nugget of information, don't fix the problem just tune around the symptom. Did you just raise the clip on one needle or all 4?
- jonarmstrong
- donthaveakawman
- Visitor
/I saw the engire road light up last night, the needle clip positon gave it a nice toasty flame ball.
- jonarmstrong
