Deleting airbox
- Koze
1979 KZ650-D2
- loudhvx
- Thank you received: 1616
You should put a breather on the crankcase vent too.
Also, we could help better if you had your year and model in your signature.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Koze
1979 KZ650-D2
- loudhvx
The only problem is what to do with all of the junk you pull off from above the motor.Koze wrote: Sig fixed... My apologies. Yes, do plan on getting the breather for crankcase. Saw elsewhere that I can delete the whole "clean air system". Am I asking for problems?
I will try to post some photos of the latest, simplest, cheapest ($ 0.65) way to block off the valve cover ports.
1981 KZ550 D1 gpz.
Other links.
- jonarmstrong
- Thank you received: 13
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
- Proxy
- 80% Human 20% Nuts/Bolts
- Thank you received: 46
Koze wrote: Going to use pod filters. What do I do the air flow hose that goes from old airbox to vacuum switch valve? Also is there anything else I have to do besides rejet?
This is like saying "so then all I have to do is recalibrate the influx distribution module to resonate with the red spectrum without destroying the containment field and turning the whole universe into a matter sucking hole before midnight tomorrow. With a paperclip, a small cylinder and a ball of twine."
Just kidding but you have searched the archives on "Pods vs airbox" right. Eyes wide open.
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- Matteson
- Thank you received: 6
KZ 900-a4
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- jonarmstrong
- Koze
1979 KZ650-D2
- daveo
- Thank you received: 662
