- Thank you received: 5
29 smoothbore boots
- flhwesty
23 Apr 2013 10:09 #583676
by flhwesty
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1981 GPz1100 KZ1100-B1
29 smoothbore boots was created by flhwesty
Going to buy new boots for my Z1R, iit has 29s on it. What boots do I need. Will stock due??
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
- Mark Wing
- Thank you received: 22
23 Apr 2013 12:58 #583687
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic 29 smoothbore boots
If you can find them for a Z1 with 28's they work great.
Mark
Mark
Yorba Linda Cal.
- 79MKII
- Love Them Kaws!
- Thank you received: 43
23 Apr 2013 14:52 - 23 Apr 2013 14:56 #583711
by 79MKII
The Kaw List:
Replied by 79MKII on topic 29 smoothbore boots
'79 and '80 1000 A models and the 80 B model LTD also have 28mm carbs so those should work too.
EDIT: '78 and '80 Z1-R's also came stock with 28mm carbs....stock replacement boots should be fine for the 29mm smoothbores.
The Kaw List:
Last edit: 23 Apr 2013 14:56 by 79MKII.
- flhwesty
23 Apr 2013 15:09 #583714
by flhwesty
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
Replied by flhwesty on topic 29 smoothbore boots
Ok thanks for answers. I have a set of 26mm boots at home, brand new, was hoping to use them. I will just go ahead and order the proper ones.
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
- testarossa
- Thank you received: 82
23 Apr 2013 16:16 - 23 Apr 2013 16:17 #583719
by testarossa
The boots for 26mm carbs are the same as 29's. You should be good with the boots you have.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Replied by testarossa on topic 29 smoothbore boots
flhwesty wrote: Ok thanks for answers. I have a set of 26mm boots at home, brand new, was hoping to use them. I will just go ahead and order the proper ones.
2004 ZX-10R
Angola, IN
Last edit: 23 Apr 2013 16:17 by testarossa.
- flhwesty
23 Apr 2013 16:23 #583720
by flhwesty
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
That is what I was hoping to hear!!!!!
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
- trianglelaguna
- Thank you received: 235
23 Apr 2013 18:57 #583750
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic 29 smoothbore boots
yep...it is the same p.i.t.a. as 26's ..i sometimes sit over the bike tank off and push evenly in on my 29's as they seems to feel like they are not in all the way ,even when they are...but the 73-79 boots will all work,,,,,
1976 KZ900
2003 ZX12R
2007 FZ1000
