- Thank you received: 52
The Pine Sol Soak
- kzz1king
21 Apr 2013 00:25 #583388
by kzz1king
Home built KZ1000 turbo setup
The Pine Sol Soak was created by kzz1king
Dropped the carbs in straight pine sol tonight. How long do you let them soak? Any downside to not rushing it? Thanks.
Wayne
Wayne
- MFolks
- Thank you received: 540
21 Apr 2013 00:31 #583390
by MFolks
Replied by MFolks on topic The Pine Sol Soak
I'd check them after an hour, if no damage(discoloration), try several hours, but not overnight.
- jeffasaki
- Thank you received: 44
21 Apr 2013 00:44 #583393
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Replied by jeffasaki on topic The Pine Sol Soak
if you wanna speed it up
50/50 with water
boil once and let cool
it helps to have a big pot
and no wife
to use this procedure
50/50 with water
and no wife
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- kzz1king
21 Apr 2013 16:12 #583447
by kzz1king
Wayne
Replied by kzz1king on topic The Pine Sol Soak
Sounds like a good method but if you start with a wife you may not have one when you get done. Mine still hasn't forgotten I used her pot to boil my deer heads!jeffasaki wrote: if you wanna speed it up
50/50 with water
and no wife
Wayne
- Kidkawie
- I bleed premix
- Thank you received: 245
21 Apr 2013 22:53 #583491
by Kidkawie
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Replied by Kidkawie on topic The Pine Sol Soak
I sat them overnight, no prob.
1975 Z1 900
2004 KX125
- kzz1king
22 Apr 2013 18:30 #583577
by kzz1king
I soaked them close to 24 hours and have noticed no problems other than jets getting a dark color. Cleaned the grease off really nice but the carbs have that dull gray that old carbs have. I don't think the pinesol caused any change in the color of the aluminium. shiny parts in and they still came out shiny!
Wayne
Wayne
- Kidkawie
- I bleed premix
23 Apr 2013 09:31 #583672
by Kidkawie
1975 Z1 900
2004 KX125
1975 Z1 900
2004 KX125
- turboking
- Thank you received: 106
23 Apr 2013 09:59 #583675
by turboking
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Replied by turboking on topic The Pine Sol Soak
did a great job... :blink:
1985 GS 1150E
1983 GS 1100E
