- Thank you received: 3
VM24ss gas path
- KowalskiCW
16 Apr 2013 12:45 #582660
by KowalskiCW
VM24ss gas path was created by KowalskiCW
Hopefully a quick one. I'm rebuilding my carbs and noticed the gas tube connectors between carbs are lookin a bit old. I'd like to reuse them but not sure they will continue to make a gas tight seal. Any advice what to use like a grease or soak them in something to bring the rubber back to life? Or should I be safe and order new parts?
- jeffecor
- Thank you received: 1
16 Apr 2013 12:58 #582663
by jeffecor
1980 Kawasaki 750 h1 ltd
Replied by jeffecor on topic VM24ss gas path
I'm going to take a guess they are o rings. Switch i just replace on my kz750 with a kit of different size of o rings from harbor freight for 6 dallors.
- KowalskiCW
16 Apr 2013 13:21 #582664
by KowalskiCW
Replied by KowalskiCW on topic VM24ss gas path
Well actually they are more like rubber sleeves with o-ring type bumps molded into them. I've seen replacement parts that do just have two o-rings I could order just trying to save pennies.
- Thank you received: 2829
16 Apr 2013 13:41 #582667
by 650ed
Replied by 650ed on topic VM24ss gas path
Correct. Kawasaki (actually Mikuni) did not use o-rings on those tubes (they are called "Fuel Hose Nipples") on VM24 carbs. Some aftermarket pieces, like those sold by Z1E, do use o-rings. Ed
- KowalskiCW
16 Apr 2013 13:53 #582669
by KowalskiCW
Right so you think just some petroleum jelly or white lithium grease on them during reassembly would help seal? I don't think they were leaking much if any before the rebuild but who knows my carbs were fairly dirty coming off.
16 Apr 2013 14:10 #582674
by 650ed
Put them together and turn on the fuel. They may leak a little after being dry for a while, but after the fuel soaks them they may stop leaking. A few years ago I had my bike in the basement doing some work on it over the Winter. I had drained the carbs and removed the fuel tank to avoid any possible fire hazard. In the Spring when I took the bike outside and put the tank on, the "T" fitting between carbs 2 & 3 began leaking where it connects to the carbs. They had never leaked before. I shut off the petcock and figured I needed to find a new "T", but by the next day the "T" had stopped leaking. It has not leaked a drop since then and that was more than 5 years ago. Ed
- KowalskiCW
16 Apr 2013 14:29 #582682
by KowalskiCW
Huh alright I'm all about savin dough for other parts on my project! I'll just put a small amount of jelly on them now and wipe them clean before reassembly which may be a couple weeks.
Thanks
Thanks
