- Thank you received: 1
1980 kz 750 h1 carb rebuild
- jeffecor
16 Apr 2013 11:32 - 16 Apr 2013 11:38 #582652
by jeffecor
1980 Kawasaki 750 h1 ltd
1980 kz 750 h1 carb rebuild was created by jeffecor
I'm clean a carb set i got off eBay last year for 30 dollars so i figure i would post the take apart and cleaning from them. If i can get some comments if I'm cleaning them right. thanks
Last edit: 16 Apr 2013 11:38 by jeffecor.
- jeffecor
16 Apr 2013 11:40 #582653
by jeffecor
Replied by jeffecor on topic 1980 kz 750 h1 carb rebuild
more of take part.
- jeffecor
16 Apr 2013 11:41 - 16 Apr 2013 11:47 #582654
by jeffecor
more
I'm taking them one of the time and keep part's together. A problem I run into on carb1 was the pilot screw would not come out of carb. So I'm working on getting the Plug pilot out of the part set I have looks like I need to drill it out.
Last edit: 16 Apr 2013 11:47 by jeffecor.
- JR
- Thank you received: 449
16 Apr 2013 17:57 #582705
by JR
Replied by JR on topic 1980 kz 750 h1 carb rebuild
Just a few tips
I use small bowls numbered 1 2 3 4 to hold the little pieces from carbs 1 2 3 4 and to soak with carb cleaner
Check the diaphragms for pinholes
Wear safety glasses when spraying carb cleaner down holes because will shoot up somewhere else and dissolve eyeballs
Use guitar string or better yet a nylon bristle or fishing line to poke all holes
In pics IMG0297 & 298 open the throttle flaps/butterflies and look up to just about where the flap would close. You will see 3 tiny holes. I use a pin with the tip bent at 90 degrees to make sure these holes are clean . If plugged then expect a stumble at about 3000rpm.
Blow everything out with compressed air. Repeat.
Don't rush
A Q tip soaked in carb cleaner works well for float valve seats. Use Brasso for very dirty seats
Good luck
Don't rush
Good luck
The following user(s) said Thank You: jeffecor
- jeffecor
17 Apr 2013 10:26 #582787
by jeffecor
Well i figure the Q tip one out and i have been soaking the in a gallon of carb cleaner for a day each.
I well check for some pin holes in the diaphragms.
I well find some fishing line to run throw the holes.
So far i got carb 2 and 3 cleaned, but noticed that the float bowl needles was compressing the spring's on all but one carb and i have read on here that's it time to replace them so i order three new needle last night.
