- Thank you received: 663
BS34 PILOT JET PLUGS
- daveo
16 Apr 2013 02:27 #582613
by daveo
1982 KZ1100-A2
BS34 PILOT JET PLUGS was created by daveo
Anyone have a source for the rubber plugs, which I've heard (or read) were used on the Mikuni BS34, Suzuki carburetors?
I have great difficulty removing the metal w/O-ring plugs, without ruining them with pliers or vise-grips, and will likely have to replace them next time I'm in there.
:huh:
:huh:
1982 KZ1100-A2
- OnkelB
- Thank you received: 80
16 Apr 2013 05:20 - 16 Apr 2013 05:21 #582626
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic BS34 PILOT JET PLUGS
Z1 Enterprises have them - I had the same problem as you, po installed the plugs too deep, had to drill them out. Replaced them with a set of rubber plugs, worked like a charm:
CLICK
Btw, if I remember correctly the price is for a set of four.
CLICK
Last edit: 16 Apr 2013 05:21 by OnkelB.
