- Thank you received: 1
carb cleaning/ adjustment
- dan123
14 Apr 2013 21:55 - 14 Apr 2013 21:57 #582340
by dan123
1982 kz550C LTD
carb cleaning/ adjustment was created by dan123
i have my carbs out and i just finished cleaning all the jets and passageways and such. everything looks good but i want to know if there is something that i am forgetting to do, or should adjust before i install them again. im new to this and would hate to have to pull them out again. when the engine was running i was noticing an odd knocking noise on the left side of the engine so i dont know if the that was because of the carbs or not. anyway im rambling now, advice would be greatly appreciated. thanks
82 kz550 LTD
82 kz550 LTD
1982 kz550C LTD
Last edit: 14 Apr 2013 21:57 by dan123.
- ironkaw5050
15 Apr 2013 09:43 #582437
by ironkaw5050
Replied by ironkaw5050 on topic carb cleaning/ adjustment
hello
I dont want to make you fell stupid but did u actually pull both main and pilots out and look threw them. The only reason i say this is i see this alot where people said they cleaned thier carb by just pulling the bowl of and spaying break clean. Im sure you pulled everything and did it the right way. i always take float needles out and clean them make sure there not sticking by putting them back in and the floats turn the carb over so they are right side up and just manually tap your floats up and down with your finger and whatch the needle make sure its moving right along.
2nd note is it a ticking or nocking top or bottom. start with your spark plugs ive seen the gaps close up on them and when that happens it will make a tick and usually run like crap.
Hope this helps
Hope this helps
- Thank you received: 2829
15 Apr 2013 09:52 #582440
by 650ed
Replied by 650ed on topic carb cleaning/ adjustment
While you have the carbs off the bike set up a stand and do the clear tube test for fuel level. They may not need to be adjusted, but if they do it will be easier with them off the bike. Ed
- dan123
15 Apr 2013 16:25 #582494
by dan123
1982 kz550C LTD
Replied by dan123 on topic carb cleaning/ adjustment
yes i took out all the jets and the needles too. the noise was much more of a knocking and i think it was coming from near the top of the cylinder, i will definitely change the plugs and see if that helps. also thank you ed i will do that as well. do you need to buy the tube from kawa or can you just use some tubing from the hardware store? thanks
1982 kz550C LTD
- donthaveakawman
- Visitor
15 Apr 2013 17:47 #582518
by donthaveakawman
Replied by donthaveakawman on topic carb cleaning/ adjustment
chances are you will take them off again so don't waste any time and just install them.
- Spectre1982
- Thank you received: 9
15 Apr 2013 18:23 - 15 Apr 2013 18:35 #582525
by Spectre1982
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
Replied by Spectre1982 on topic carb cleaning/ adjustment
Is it a knocking sound or a ticking sound?
EDIT: Reread posts and see it's knocking. Oops!
1978 Kawasaki KZ200
Last edit: 15 Apr 2013 18:35 by Spectre1982.
15 Apr 2013 19:25 - 15 Apr 2013 19:25 #582531
by 650ed
If you can find online or make a carb tool that screws into your drain plug and has clear tubing attached that should work best. If not, some folks just find clear tubing that is a snug fit in the drain hole and use it. It doesn't need to be special Kawasaki tubing as it will only have fuel in it for a few minutes during the test. Do a search on this site for "clear tube test" and you may find some examples. Ed
Last edit: 15 Apr 2013 19:25 by 650ed.
- donthaveakawman
- Visitor
16 Apr 2013 19:17 #582714
by donthaveakawman
check the vent tubes for cracks although they are hard to see make sure they are clean before you repair them. I wonder if jb weld would have worked.
Attachment 560127_322475077879768_1373063554_n.jpg not found
- dan123
16 Apr 2013 20:07 #582724
by dan123
1982 kz550C LTD
ohh crap i just realized that the boots i ordered say they are for models up to 1980......mines an 82. does anyone know what the difference is and if i can make them work for my bike?
1982 kz550C LTD
