- Thank you received: 1
Carb Interchange
- geohaydook1
13 Apr 2013 13:20 #582144
by geohaydook1
1980 KZ750e
1981 KZ650 csr (fate undecided)
Carb Interchange was created by geohaydook1
Okay,
What carbs will work on a 750 E1? I just bought this bike and have discovered the p.o. broke the carb body while trying to drill out the epa plug the covers the pilot screw. To make it worse, he also snapped off the top of the screw making itself it impossible to remove. :pinch: Any ideas?
David
David
1980 KZ750e
- JR
- Thank you received: 449
13 Apr 2013 20:27 #582193
by JR
Replied by JR on topic Carb Interchange
The 750E1 came with Keihin CV34 carbs and the later (1983?) 750s came with Mikuni BS34s which should work the same. Just make sure that whatever carbs you get came off a 750/4 1980 - 1983 possibly also 84 + but I'm not sure on this.
Some of the larger KZs also came with BS 34s but the jetting and spacing may be different than for the 750.
- Thank you received: 1656
13 Apr 2013 21:16 #582197
by martin_csr
Replied by martin_csr on topic Carb Interchange
The carb holders & airbox ducts are the same on just about all of the KZ750-4s and all the airboxes are just about the same, so the carburetors from just about any 750-4s should work.
- steell
14 Apr 2013 15:41 #582276
by steell
Replied by steell on topic Carb Interchange
KZ650/700/750/900/1000/1100 all have the same carb spacing. Other details differ though.
- geohaydook1
14 Apr 2013 17:55 #582292
by geohaydook1
1980 KZ750e
Replied by geohaydook1 on topic Carb Interchange
Good to know. Now does anybody have a set they're willing
To part with? Prefer VMs but not picky.
1980 KZ750e
- geohaydook1
15 Apr 2013 12:40 - 15 Apr 2013 12:43 #582465
by geohaydook1
1980 KZ750e
Sorry, meant to say CV's, since that's what I've got parts for But I'd be happy
To find a set of BS34's. I just would like to avoid eBay. You never
Really know what you're getting there. Thanks,
David
David
1980 KZ750e
Last edit: 15 Apr 2013 12:43 by geohaydook1. Reason: Typo
