- Thank you received: 13
Syncing issue or much more?
- jonarmstrong
15 Apr 2013 23:25 #582579
by jonarmstrong
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
Replied by jonarmstrong on topic Syncing issue or much more?
Yes the screws on top near intake. 1 1/2 turn is pretty standard starting point till u can put the guages on it. Guages are the only way to get it precise.
The following user(s) said Thank You: magruder13
- NovaNewfie
- Thank you received: 3
15 Apr 2013 23:56 #582589
by NovaNewfie
1979 KZ1000E-1 ST
Replied by NovaNewfie on topic Syncing issue or much more?
If you have a vacuum petcock that's not hooked to your carbs then you have an open hole on one of your carbs to lose vacuum through the same as if you had a bad intake boot. You should look real close at your carbs or your intake boots and see if there is a nipple there that is not plugged.
1979 KZ1000E-1 ST
- jonarmstrong
16 Apr 2013 00:35 #582596
by jonarmstrong
+1
- magruder13
17 Apr 2013 19:43 #582852
by magruder13
1982 Honda XL125S
1972 Yamaha TX750 (CB750 engine)
1976 Kawasaki KZ400
Replied by magruder13 on topic Syncing issue or much more?
Just to follow up, I went ahead and bought a sync kit. The bike is at home and I'm at college (I go home on the weekends) so I'll check the vacuum leak and get that hose hooked up asap! I'll post my results here!
1982 Honda XL125S
1976 Kawasaki KZ400
- jonarmstrong
18 Apr 2013 10:39 #582947
by jonarmstrong
My bike sat for years (like 15) and it took some serious cleaning to get the carbs right. I had them apart at least 5 times. I soaked them in a carb cleaner basket from advance auto first but couldn't get a stable idle either. The last thing I did was take them apart and blow every hole out w an air hose. It cured my bike. Runs like a bat out of hell now and i have no problems w idle. Check ur pilots to be sure they are open if all is clean it still sounds like a vacuum leak.
- magruder13
18 Apr 2013 17:03 #582973
by magruder13
1982 Honda XL125S
1976 Kawasaki KZ400
Just a quick question here, what is this part and where does it go?
After disassembling the carbs I never saw one, the PO bought a kit and installed it into one of the carbs (not sure what one) and this was in the parts bag he gave me.
1982 Honda XL125S
1976 Kawasaki KZ400
- donthaveakawman
- Visitor
18 Apr 2013 18:06 #582979
by donthaveakawman
Replied by donthaveakawman on topic Syncing issue or much more?
that part is the cover for the part above it.
