carb swap
- RustedAce
10 Apr 2013 09:25 #581572
by RustedAce
81 kz 750 ltd
carb swap was created by RustedAce
I have an 81 kz 750 ltd. diaphrams on slides leaked. looked around and were rather pricey to rebuild. got a set of carbs off an 83(i think) gpz 750 all looks good for swap other than no mount for throttle cable. wondering if any ideas or solutions. If not ill have to engineer something
81 kz 750 ltd
- baldy110
- Thank you received: 512
10 Apr 2013 12:55 #581617
by baldy110
Replied by baldy110 on topic carb swap
Those GPz carbs should just bolt on your bike without issues. If they have the stock jetting they should alos work as is.
- RustedAce
10 Apr 2013 15:42 #581651
by RustedAce
81 kz 750 ltd
Replied by RustedAce on topic carb swap
everything looks good except for no place to mount throttle cable. the part to actually hook to butterfly it there just the mount is missing where lock nuts to is not there. wondering if its just missing not sure what was supposed to be there anyone have a diaghram of gpz carbs?
81 kz 750 ltd
- wireman
- Thank you received: 299
10 Apr 2013 15:56 #581655
by wireman
Replied by wireman on topic carb swap
Attachment 83gpz750.gif not found
- RustedAce
11 Apr 2013 15:50 #581854
by RustedAce
81 kz 750 ltd
Maybe I'm missing it but does anyone else see a tab to mount throttle cable on those?
81 kz 750 ltd
