- Thank you received: 13
TK22 Vacuum Lines and Misc Question
- The_Proletariat
- "Cocaine is a hell of a drug"
09 Apr 2013 21:36 - 09 Apr 2013 21:37 #581484
by The_Proletariat
What are these lines? Fuel bowl vent hoses? I cannot remember where they connect to but from how blown out the ends are they were sure connected to something. It was not to the air injection valve, carbs two and three were connected to that with the nipple on the carb holders.
A couple more TK22 questions.
Is it necessary to separate each carb from the plate for a full rebuild?
And what lube should I use on the throttle slides?
1982 Kawasaki KZ550 LTD
TK22 Vacuum Lines and Misc Question was created by The_Proletariat
Last edit: 09 Apr 2013 21:37 by The_Proletariat.
- GPz550D1
- Thank you received: 22
09 Apr 2013 21:52 #581492
by GPz550D1
1981 KZ550-D1
Replied by GPz550D1 on topic TK22 Vacuum Lines and Misc Question
The hoses pointed to are just vent hoses. They go up and fit on the top part of the air box, not blocking the air intake. One fits down the left side and one on the right. No need to separate each carburetor from the plate.
Robert
Robert
1981 KZ550-D1
The following user(s) said Thank You: The_Proletariat
- Thank you received: 2098
09 Apr 2013 22:20 #581504
by Patton
Replied by Patton on topic TK22 Vacuum Lines and Misc Question
And no lube on the throttle slides.
