- Thank you received: 3
Vent lines on stock 28's
- NovaNewfie
08 Apr 2013 07:53 #581155
by NovaNewfie
1979 KZ1000E-1 ST
Vent lines on stock 28's was created by NovaNewfie
I'm working on the carbs on an original '79 KZ1000E-1 its Canadian spec. Can someone tell me if the vents off of #2 & 4 carbs are supposed to go back to the two hose barbs that are on the left side of the airbox by the air intake elbow?
Thanks
Thanks
1979 KZ1000E-1 ST
- Roadflyer
- Thank you received: 13
08 Apr 2013 12:51 #581188
by Roadflyer
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
Replied by Roadflyer on topic Vent lines on stock 28's
I have a 79 KZ1000 E-1 as well. Mine doesn't have any airbox barbs that I could see. I just ran the vent lines over the airbox, but having them connected to the airbox would have been better.
NovaNewfie wrote: I'm working on the carbs on an original '79 KZ1000E-1 its Canadian spec. Can someone tell me if the vents off of #2 & 4 carbs are supposed to go back to the two hose barbs that are on the left side of the airbox by the air intake elbow?
Thanks
The following user(s) said Thank You: NovaNewfie
- Thank you received: 2098
08 Apr 2013 13:14 - 08 Apr 2013 13:25 #581192
by Patton
Replied by Patton on topic Vent lines on stock 28's
Here's the stock carb vent hose routing on 1976 KZ900-B1 LTD.
Some owners allow the hoses to hang down from the vent nipples a short distance or route longer hoses to exit into open air underneath the bike.
Or the nipples could be left uncapped without any hose connected.
The important point is to allow the vent nipples to "vent" and not be in any way obstructed or prevented from connecting to open atmosphere.
Exiting into the air box is considered the same as opening to atmosphere.
The two carb vent nipples serve to vent all four carb float bowls, which venting prevents so-called "vapor lock."
Such venting of the carb bowls serves the same purpose as venting the fuel tank via the cap, being to promote free gravity flow of fuel.
Last edit: 08 Apr 2013 13:25 by Patton.
- NovaNewfie
08 Apr 2013 20:06 - 08 Apr 2013 20:09 #581249
by NovaNewfie
1979 KZ1000E-1 ST
Replied by NovaNewfie on topic Vent lines on stock 28's
If these pictures load the hose barbs pictured are the ones I was talking about.
1979 KZ1000E-1 ST
Last edit: 08 Apr 2013 20:09 by NovaNewfie. Reason: Photos
- Roadflyer
11 Apr 2013 14:42 #581844
by Roadflyer
I don't think my bike has those, I prefer to run the hoses over the air box for a cleaner install that trying to route them down to the barbs.
NovaNewfie wrote: If these pictures load the hose barbs pictured are the ones I was talking about.
