Needle adjustment
- Fastdave61
05 Apr 2013 16:47 #580736
by Fastdave61
1969 BSA A65F Firebird
2004 BMW R1150RT
1980 Kz1000G1
2008 Triumph Tiger 1050
Bemidji, Mn
Needle adjustment was created by Fastdave61
I need a little help regarding a set of 26mm Mikuni carbs, they are off the bike and on my work bench. I need to adjust the needle setting. My question is "how do I get to the needle"? Through the top I assume. A little detailed instruction would be appreciated. This is the end of a 2 year project and this site has been very helpful. Thanks in advance.
2004 BMW R1150RT
1980 Kz1000G1
Bemidji, Mn
- 4TheKZ1000
- Visitor
05 Apr 2013 17:25 - 05 Apr 2013 17:35 #580739
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Needle adjustment
take tops off carbs
remove the (1) hex bolt not hex nuts that holds the 4 slides to throttle shaft.
you have to take out long throttle rod that goes though carbs. You will have to remove other items connected to rod.
When throttle rod is out....the car slides will come out and you can change position of needle.
Are these the style you have?
Attachment KGrHqVHJ0E8klowoCBPWqerSt360_571024x626.jpg not found
Last edit: 05 Apr 2013 17:35 by 4TheKZ1000.
- Topper
- Thank you received: 133
05 Apr 2013 17:25 #580740
by Topper
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
Replied by Topper on topic Needle adjustment
The procedure is outlined pretty well in the manual.I'd strongly recommend getting one. Most are available in the filebase on this site (
www.kzrider.com/filebase
But yes, in general you get to the needle through the top of the carb. Be extra careful with the top disassembly. There are diaphragms in there that you don't want to tear.
1979 KZ750 Twin
