Keyster Carb Rebuild Kit Quality?
- helpermonkey
05 Apr 2013 13:46 #580710
by helpermonkey
Keyster Carb Rebuild Kit Quality? was created by helpermonkey
Looking at one of these for my KZ200. Any good? I just picked up a pristine 1978 with 252 original miles. Gas leaks out of the overflow tube on the carb so I am expecting that some internals need attention. Thanks.
- bountyhunter
- Thank you received: 337
05 Apr 2013 15:15 - 05 Apr 2013 15:16 #580722
by bountyhunter
Replied by bountyhunter on topic Keyster Carb Rebuild Kit Quality?
The ones for my 750 twin were excellent.
Gas overflow just means the needlsa/seats need cleaning and adjusting.
Last edit: 05 Apr 2013 15:16 by bountyhunter.
- zedninehunner
10 Apr 2013 08:41 #581567
by zedninehunner
1976 Z900A4, 1977 RD250 , 1999 YZF R6
Replied by zedninehunner on topic Keyster Carb Rebuild Kit Quality?
Just posted a comment here,
www.kzrider.com/forum/3-carburetor/58111...loor-puddle-syndrome
on that very subject , kits in general are good quality but wary about the float valve spring tension, if you can clean your existing ones and re use I would recommend that first.
Might save you some money, but if also need jets/needles/gaskets etc the kits supply everything you need and are of good quality.
