Jetting help needed
- morhaven
03 Apr 2013 14:04 #580385
by morhaven
Jetting help needed was created by morhaven
Hi i have a 79 kz 1000 st.
Stock exhaust.
Pods x4
I cant figure out what main jet, idle jet and needle position i should use.
Thanks.
Stock exhaust.
Pods x4
Thanks.
- morhaven
04 Apr 2013 13:50 #580545
by morhaven
Replied by morhaven on topic Jetting help needed
anyone have any tips..
or how many size to go up with Pods?
- mike0537
- Thank you received: 6
05 Apr 2013 03:44 #580652
by mike0537
1980 KZ750E
Replied by mike0537 on topic Jetting help needed
I'm not 100% sure but I think stock jets are okay when just adding pods. It's when you add pods and aftermarket exhaust that you must re-jet.
1980 KZ750E
- Old Man Rock
- Thank you received: 225
05 Apr 2013 07:59 - 05 Apr 2013 08:24 #580664
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Jetting help needed
Basic rule of thumb as follows but please note, also depends on other factors such as elevation, temperatures, humidity etc....
Condition of plugs sooty (rich) or running lean...?
Also insure valve clearance, timing, power to coils, ignition components (points/conder or EI) is all to spec.... Not to mention Carbs are sync'd to spec.
Another article I found that made sense...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 05 Apr 2013 08:24 by Old Man Rock.
The following user(s) said Thank You: etbike3135
- morhaven
05 Apr 2013 08:47 #580670
by morhaven
Great stuff thanks.. Ill give it a go.. anyone form Gatineau quebec Canada willing to help me out with some of this stuff
