- Thank you received: 2
carb holder question
- natetru
03 Apr 2013 13:06 #580381
by natetru
1982 kz1000 m2 csr
carb holder question was created by natetru
Installing new carb holders today on my 82 1000.....do these require sealant or do you install them dry?
1982 kz1000 m2 csr
- Thank you received: 2829
03 Apr 2013 14:32 #580390
by 650ed
Replied by 650ed on topic carb holder question
Dry. Ed
- natetru
03 Apr 2013 17:08 #580405
by natetru
1982 kz1000 m2 csr
Replied by natetru on topic carb holder question
Thanks, called z1enterprises tech line....he suggested slight smear of dielectric grease on sealing surface and dry on carb side....that's what I did...holy cow, what a difference no vac leaks make!
1982 kz1000 m2 csr
03 Apr 2013 18:30 #580412
by 650ed
I replaced mine on dry 9 years ago and have had no leaks since, but I doubt a light film of grease will hurt anything. The bigger concern would be folks who feel compelled to load the thing up with silicone and end up with it being sucked into the cylinders.
The difference new carb holders makes really is amazing! I suspect there are many folks who have problems with their bike idling poorly that could use a new set of holders. Ed
- MFolks
- Thank you received: 540
03 Apr 2013 18:36 #580414
by MFolks
Replied by MFolks on topic carb holder question
Replace the rubber sync plugs too, as they can develope cracks & affect the idle.
- natetru
