KZ200 1979 (Keihin carburetor) Help?
  • Raven72
  • Raven72's Avatar Topic Author
02 Apr 2013 21:47
#580289
KZ200Ae027243
It is my understanding that I have a 1979 KZ200. I discovered that the Choke Value is broken. I have the Keihin Carburetor with a stamped number of (26) on it. Sadly I only have part of the choke value the previous owner must have removed the other broken 1/2.
My problem is that all of my internet searches have completely failed in trying to locate someone that sells that part. I can't even locate the part number.
I have search at least a dozen sites and had no luck at all.
Thank you.
  • morhaven
  • morhaven's Avatar
Re: KZ200 1979 (Keihin carburetor) Help?
03 Apr 2013 14:05
#580386
Might be easier to get an entire used carb
03 Apr 2013 19:19 - 03 Apr 2013 19:29
#580417
According to Kawasaki.com the following is the carb for the KZ200. Assuming this is what is on your bike, which part do you need? Ed
Attachment 00000_2013-04-03.jpg not found
Attachment 00000a.jpg not found
Last edit: 03 Apr 2013 19:29 by 650ed.
  • Raven72
03 Apr 2013 20:34
#580424
Attachment carbpic.jpg not found
I saw the website you pulled that picture from. It looks like the same carb, but why they aren't showing the part is beyond me. Here is the picture I have showing the part. It is listed as Part 11 and called "Choke Valve"
I would love to get it functional, but being that I'm having so much trouble finding the part I might have to replace the whole carb.
The carb has identifying marks of
Keihin Japan
26 (in a circle)
p72a
OE19
I haven't found any other markings on it.
04 Apr 2013 10:24
#580525
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationThe only info I could find is that your carb appears to be a Keihin PW-26. They were used on the KZ200 and on some older Honda models, but I cannot find a parts diagram or anyone selling spares. I did find the eBay listing below selling the choke assembly for the PW-22, but it is quite pricey and I don't know if it will fit the PW-26. It may be worth contacting him to see if he has a diagram or any info on the PW-26 or if he knows if the PW-22 choke will fit it. The second eBay listing below shows pictures of the PW-22 so you can see if they look similar to your PW-26. Ed
  • Raven72
10 Apr 2013 22:43 - 10 Apr 2013 22:45
#581720
No eBay APP ID and/or Cert ID defined in Kunena configurationSadly it seems that parts for this carburetor is not possible. So I'm now shopping for a new carburetor. I don't know much of anything on how to selecting a replacement. I saw several postings for PZ 26. such as
Any direction on how to go about selecting a replacement carburetor would be appreciated.
how is the PW26 different from a PZ26? The ones listed (pw26) on ebay currently don't look correctly for what I'm replacing.
Last edit: 10 Apr 2013 22:45 by Raven72.
  • gunner
  • gunner's Avatar
19 Oct 2013 23:10
#610569
Hey raven,
Did you have any luck with finding a carb to fit your kz200? I am having a similar problem - just picked up a "78 kz200 ... the carb seems in pretty good shape except possibly for the float valve and the pilot jet. I can't seem to find anything to tell me if a newer carb will fit without doing a retrofit.
The other part I am having trouble finding is a starter clutch gear.
KZ200
Toronto
19 Oct 2013 23:38
#610575
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
