- Thank you received: 2
Throttle lever won't reach throttle stop screw
- daless
31 Mar 2013 15:21 #579816
by daless
'77 KZ1000A1 - Mikuni VM29s, Kerker 4-1, K&N pods, LTD mags, Z2 seat
Throttle lever won't reach throttle stop screw was created by daless
Continuation of
thread from the engine section
. Figured I'd switch to here where it belongs.
Been a while since I've had much time to figure things out, but I'm still stuck trying to get the bench sync right. I left off with the advice below from Patton, but still can't get the throttle lever up to the open stop screw and want to get this taken care of before going any further.
Can anyone go into further detail on this? Can't seem to figure it out with Clymer or Sudco. I must be missing something.
Patton wrote: A mistake is sometimes made during the bench sync by failing to leave sufficient thread remaining on the idle adjustment screw to permit further lowering the throttle slides as is often required during the later running sync.
This error is what may cause the problem described as, the throttle lever never comes into contact with the throttle stop screw. Is that right? The screw seems effectively useless....
- Thank you received: 2098
31 Mar 2013 15:36 - 31 Mar 2013 15:38 #579818
by Patton
Replied by Patton on topic Throttle lever won't reach throttle stop screw
During the bench-sync procedure, while setting the throttle slide heights to lowest equal positions, the idle adjustment screw should be touching the stop, and with sufficient thread left remaining to permit further lowering of the throttle slides.
Last edit: 31 Mar 2013 15:38 by Patton.
- daless
31 Mar 2013 16:16 #579821
by daless
Replied by daless on topic Throttle lever won't reach throttle stop screw
Okay, thanks. I'll see where that gets me next chance I have to get in there.
