Cant find a way to put reverse cable in the carb
- tomekzski
30 Mar 2013 17:55 - 30 Mar 2013 18:45 #579636
by tomekzski
1982 Honda cm250 c *cafe* -sold
1979 Honda cb650 *stock* -sold
1990 Kawasaki zx600r -sold
1980 Kawasaki kz750 LTD *Cafe*
Cant find a way to put reverse cable in the carb was created by tomekzski
Hey i have a 1980 kz750 ltd and i cant find a way to connect the reverse throttle cable to the carb. any way i can get a diagram for the carb? does it go to the end where the filters are or more towards the motor?? help please!!
thanks,
TOM
[see Classifieds-Wanted]
thanks,
TOM
Last edit: 30 Mar 2013 18:45 by Patton.
- gengomerpyle
- Thank you received: 17
30 Mar 2013 18:30 #579645
by gengomerpyle
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
Replied by gengomerpyle on topic Cant find a way to put reverse cable in the carb
which carbs are they?
1982 GPZ750R1 ELR
1971 Honda CB750K
- Proxy
- 80% Human 20% Nuts/Bolts
- Thank you received: 46
30 Mar 2013 18:54 #579653
by Proxy
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
Replied by Proxy on topic Cant find a way to put reverse cable in the carb
Just work the throttle to see which one pulls when you twist the throttle. Then move the throttle cam and it should be evident where it has to go. My favorite tool to use are hemostats to do this job. Then after I attach the pull cable I pull it up and wedge it with a wrench or screwdriver. It's pretty easy to attach the return cable then. Not a favorite job but with the hemostats at least it is tolerable. Good luck.
- Rainman
- and a little Kaw shall lead them
- Thank you received: 75
30 Mar 2013 19:55 #579671
by Rainman
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Replied by Rainman on topic Cant find a way to put reverse cable in the carb
Jim
Quincy,IL
- JR
- Thank you received: 449
31 Mar 2013 00:18 #579733
by JR
Replied by JR on topic Cant find a way to put reverse cable in the carb
My 1980 kz750/4 E1 uses only a single "pull" cable even though the throttle grip is set up for a return cable. The spring on the keihin CV34 is strong enough without a return cable. I'm pretty sure my model at least was not designed to have a second cable. Yours may be the same.
Good Luck
Good Luck
- mtkawboy
- Thank you received: 16
05 Apr 2013 16:40 - 05 Apr 2013 16:41 #580735
by mtkawboy
Replied by mtkawboy on topic Cant find a way to put reverse cable in the carb
On any of them its a whole lot easier to remove or install the cables before you put the carbs in the manifolds. Same thing with any fuel lines you plan to change
Last edit: 05 Apr 2013 16:41 by mtkawboy. Reason: spelling
