- Thank you received: 2
Have to snap the throttle to lower idle speed.
- ironslave
- sup
1981 KZ750 LTD
- trianglelaguna
- Thank you received: 235
there should be some play in these two spots...also...if you have the bike running and turn the idle set screw at the carbs out...idle down...does it die eventually ...does the idle screw adjust/set idle like it should??
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- Proxy
- 80% Human 20% Nuts/Bolts
- Thank you received: 46
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
- donthaveakawman
- Visitor
-edit(you have to give these guys a break, they have no idea what the question is until somebody answers it)
- ironslave
- sup
donthaveakawman wrote: pb blaster 10w-d-40, 3 in one tranny fluid, motor oil whatever is clever.
so put it on the springs between the carbs? what about dirt buildup?
1981 KZ750 LTD
- peter1958
- Banned
- Thank you received: 198
- baldy110
- Thank you received: 512
- Bluemeanie
- Thank you received: 14
- Thank you received: 2098
Also, the throttle mechanism might be located to allow inside of the throttle grip to rub against end of the handlebar.peter1958 wrote: If the handle is to close to the controls it can hang up as well.
If not already done, would assure the grip isn't rubbing against end of the handlebar.
- kawasaki mike
- kawasaki mike
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
- ironslave
- sup
as far as the cable goes, there are no tight bends and the handlebar is not a problem. the cable mooves freely.
1981 KZ750 LTD
- baldy110
The vacumn slides do not effect idle period. The idle sircuit is controlled by the pilot jets and idle mixture scews. You can let the bike idle and raise the slides manually and it won't do anything so do not start messing with those. They are supposed to come down slowly and they are controlled by engine vacumn.
