- Thank you received: 9
Pilot Jet
- Spectre1982
29 Mar 2013 18:52 #579501
by Spectre1982
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
Pilot Jet was created by Spectre1982
I extracted a stripped pilot jet from one of my carbs. When I bought a new jet, I noticed it has the cross flow holes that go horizontally and it also has a hole going through the screw slot vertically. I can see light through it. I asked before if there were supposed to be vertical holes in the pilot jet. I was informed that there is no hole there. Does anyone know positively if there is or isn't supposed to be a vertical hole in the pilot jet? It's the one that has the plastic plug covering it. If there is a hole there, three of my carbs are plugged on the pilot circuit. I'd probably have to drill it out because guitar wire wouldn't bust through it. My bike runs great but I never could get it to idle on its own. I always give it a bit of "maintenance" throttle. Any help is greatly appreciated.
I've got completely stock Keihin carbs on the 750 N1.
1978 Kawasaki KZ200
- Spectre1982
30 Mar 2013 10:13 - 30 Mar 2013 13:12 #579574
by Spectre1982
1978 Kawasaki KZ200
Replied by Spectre1982 on topic Pilot Jet
Here's a picture in case it's unclear.
EDIT: It's not letting me post my pictures.
1978 Kawasaki KZ200
Last edit: 30 Mar 2013 13:12 by Spectre1982.
- Thank you received: 2829
30 Mar 2013 11:12 #579582
by 650ed
If you're using FireFox you will need to switch over to Internet Explorer to post pics. It's a pain, but FireFox has not stepped up to the plate to correct the error in their latest version. Ed
Replied by 650ed on topic Pilot Jet
Spectre1982 wrote: Here's a picture in case it's unclear. I'm asking if there's supposed to be a hole through the jet where the RED arrow is.
The following user(s) said Thank You: Spectre1982
- Spectre1982
30 Mar 2013 13:14 - 30 Mar 2013 13:16 #579594
by Spectre1982
1978 Kawasaki KZ200
Thanks, Ed. That was the problem with the picture. I would never have figured that out.
Anyway, back to the pilot jet. I'm asking if there's supposed to be a hole through the jet where the arrow is.
(That isn't the actual jet, just a pic off the internet for reference.)
1978 Kawasaki KZ200
Last edit: 30 Mar 2013 13:16 by Spectre1982.
- Spectre1982
30 Mar 2013 15:25 - 30 Mar 2013 15:56 #579613
by Spectre1982
1978 Kawasaki KZ200
I pulled the carbs off and took out the jet. I cut the high E string off my guitar in hopes it would be the correct size. I ran it through the hole and sure enough it came out the other side. I can now see light coming through the jet. :woohoo:
Anyway, got it figured out. If anybody else is wondering if there's a hole there, your jet is clogged.
1978 Kawasaki KZ200
Last edit: 30 Mar 2013 15:56 by Spectre1982.
