- Thank you received: 299
Has anyone used this throttle on VM type carbs?
- DoubleDub
- Visitor
28 Mar 2013 12:45 - 28 Mar 2013 12:50 #579270
by DoubleDub
Has anyone used this throttle on VM type carbs? was created by DoubleDub
Looking to use this with Kz1000 VM28 carbs:
www.motionpro.com/motorcycle/partno/01-0058/
I'm wondering if the stock cables would work with it - they look the same as what Motion Pro shows but I don't know if the threads are different/etc.
Anyone who has actually used it - I would appreciate any feedback.
Thanks!
Thanks!
Last edit: 28 Mar 2013 12:50 by DoubleDub. Reason: Added image
- DoubleDub
- Visitor
28 Mar 2013 12:51 #579271
by DoubleDub
Replied by DoubleDub on topic Has anyone used this throttle on VM type carbs?
Also finding people reporting that older Honda throttle cables attach to it properly. Did Honda use the same threading on their cables as Kawasaki?
- wireman
28 Mar 2013 16:03 #579292
by wireman
Replied by wireman on topic Has anyone used this throttle on VM type carbs?
Ive used single cable dirt bike style throttles even though they say you shouldn't,dont remember exact motion pro number though.
- DoubleDub
- Visitor
05 Apr 2013 20:17 #580766
by DoubleDub
If anyone cares, it has two different sized threads. The push cable appears to be the same thread type as the cables on my Kz650, but the pull is a larger diameter. This throttle will require custom cables from Motion Pro.
Wish they would list this kind of crap in the product information. Oh well, it was worth a shot for $15.
- turboguzzi
- Thank you received: 72
19 Apr 2013 20:38 #583168
by turboguzzi
Replied by turboguzzi on topic Has anyone used this throttle on VM type carbs?
get in touch with corey clough at the gpz550 foeum or pm me for his email
he sometimes checks in here too
he races a 550 and works for motion pro
- DoubleDub
- Visitor
20 Apr 2013 01:34 #583233
by DoubleDub
Thanks, TG. He's on the Ahrma forum I frequent too. I decided just to use the stock throttle for now.
- mike0537
- Thank you received: 6
20 Apr 2013 03:08 - 20 Apr 2013 03:09 #583247
by mike0537
1980 KZ750E
Replied by mike0537 on topic Has anyone used this throttle on VM type carbs?
No eBay APP ID and/or Cert ID defined in Kunena configurationI bought this guy from ebay. My KZ750E uses a single throttle cable. This new piece is designed to work with single or dual cables though. Looks good too!
1980 KZ750E
Last edit: 20 Apr 2013 03:09 by mike0537.
- kzz1king
- Thank you received: 52
22 Apr 2013 18:35 #583579
by kzz1king
Home built KZ1000 turbo setup
Replied by kzz1king on topic Has anyone used this throttle on VM type carbs?
Does your stock cable thread into this? Thanks. Looking for one for my KZ 1000. I only use the single cable anyhow.
Wayne
mike0537 wrote: I bought this guy from ebay. My KZ750E uses a single throttle cable. This new piece is designed to work with single or dual cables though. Looks good too!
Wayne
- mike0537
23 Apr 2013 11:11 #583682
by mike0537
1980 KZ750E
Yes, has same thread size and pitch. Worth every penny
1980 KZ750E
The following user(s) said Thank You: kzz1king
