- Thank you received: 64
zr7 carbs to kz750
- undiablo
26 Mar 2013 20:25 #578969
by undiablo
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
zr7 carbs to kz750 was created by undiablo
Hi guys!
I have recently seen a post at kz650.info about installing a set of keihin cvk32 from a kawasaki zr7 into a kz650. Great work by the way.
Should I spect any improvement by installing this carbs into my kz750? I have stock keihin cv34, but it is getting difficult to fin new spare parts...
- baldy110
- Thank you received: 512
26 Mar 2013 21:08 #578985
by baldy110
Replied by baldy110 on topic zr7 carbs to kz750
The head spacing is the same on your 750 as the 650 so yes it should work.
- Topper
- Thank you received: 133
26 Mar 2013 21:24 #578994
by Topper
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
Replied by Topper on topic zr7 carbs to kz750
Would this result in any performance improvements?
1979 KZ750 Twin
- undiablo
26 Mar 2013 21:24 #578995
by undiablo
Replied by undiablo on topic zr7 carbs to kz750
Yes, I should use ZR7 boots too....inside carb distance is not the same.
- baldy110
28 Mar 2013 17:24 #579305
by baldy110
I doubt you gain much improvement in performance due to the carbs are basicly the same design. The ZR7 carbs have a flatslide Vrs the round slide so low end performance might be improved but I would not expect anything spectacular from them.
The following user(s) said Thank You: undiablo
- undiablo
28 Mar 2013 20:03 #579331
by undiablo
OK, I think I will stay with my old Keihins then. Thanks baldy110.
