- Thank you received: 1
Throttle Cables
- geobass
- 75 Z1-B
Thanks,
George
- Kidkawie
- I bleed premix
- Thank you received: 245
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- slayer61
- KZR FLAG RELAY CARRIER #62
- geobass
- 75 Z1-B
slayer61 wrote: FWIW I've had great luck with cables from motion pro
Motion pro it is...
Thanks
- Thank you received: 2098
If both have the same curvature, after the first is screwed into position, the second won't screw in because it's curved pipe hits the curved pipe that's already screwed in.
The shallower curve allows clearance needed to turn past the tighter curve.
- bluej58
- Thank you received: 511
Do you have stock handle bars ?
78 KZ1000 A2A
- geobass
- 75 Z1-B
bluej58 wrote: Z1E sent me two of the same cables and they work fine , you just have to figure out what order to screw them on.
To tell you the truth I have no idea. Most parts on this bike came from a kz900.
- Kidkawie
- I bleed premix
Install the pull cable and adjust it so you have the amount of free play you want. Then install the push cable. Adjust it to remove slack, constantly checking throttle action (snap close). Once the throttle return becomes a little slow, back off the push cable a turn or so.
1975 Z1 900
2004 KX125
