touchy idle adjustment screw
  • donthaveakawman
  • Topic Author
  • Visitor
21 Mar 2013 18:16 - 21 Mar 2013 18:17 #578033 by donthaveakawman
touchy idle adjustment screw was created by donthaveakawman
curious why I will be riding and the idle will fall to just barely moving on the tach then I will barely move the adjustment screw at a light or wherever I can stop, lean over and fiddle with it then it will rev up to about 2k or more unevenly.- I am currently running an entire can of berrymans b-12 cleaner through the gas.
Last edit: 21 Mar 2013 18:17 by donthaveakawman.
21 Mar 2013 19:56 #578043 by baldy110
Replied by baldy110 on topic touchy idle adjustment screw
Don't do that, berrymans will eat rubber. There is no such thing as a "mechanic in a can." If you are having problems then fix the problem do not rely on something out of a can to fix it. Check your manifolds for leaks.
  • donthaveakawman
  • Topic Author
  • Visitor
21 Mar 2013 21:28 #578059 by donthaveakawman
Replied by donthaveakawman on topic touchy idle adjustment screw
already done, I had some spray berrymans b-12 (not vitamin b12) that I sprayed around the intakes and they are all sealed. I went about 180 miles since I dumped it in and no leaks at this point.
I am pretty sure with this weather it is the engine is too cold at such speeds in the cold.
I think that is also why it cuts out and putters for a while then jolts real quick like something breaks loose.
good to keep some upper cylinder lubricant in the gas as to not rev it while it is cold and bust up the piston rings.
22 Mar 2013 00:26 - 22 Mar 2013 00:27 #578084 by baldy110
Yeah right, My bike runs the same regardless of how cold or hot it gets. I have ridden mine in temps down to 10 degrees and as hot as 120 degrees once warmed up it runs fine either way. If the carbs are tuned properly you will not have any problems with temperatures. On second thought just pour in a quart of MEK while your at it, that will fix anything.
You have a problem but I guess you know more than I do so you can diagnose it then fix it without any help.
Last edit: 22 Mar 2013 00:27 by baldy110.
  • donthaveakawman
  • Topic Author
  • Visitor
22 Mar 2013 00:29 - 22 Mar 2013 01:43 #578085 by donthaveakawman
ok what should I start with? diagnosis time with don the caveman. bike runs good for a few hours then cuts out and rumbles for a while then takes off again. what do you suggest? heet? gasline antifreeze?
Attachment needlejet_2013-03-21.jpg not found
as you can see the old needlejets were sticking- see the groove.
Attachment plugfoul.jpg not found
here is the plugs I can't tell if they are fouling one way or another.
Attachment lllll018.jpg not found
Last edit: 22 Mar 2013 01:43 by donthaveakawman. Reason: add photos
22 Mar 2013 12:27 #578137 by baldy110
Put everything back to STOCK settings and get a baseline. Do a systamatic trouble shooting and you will eventually find what is wrong. Stop doing modifications to stuff to try and fix a problem. The way you are doing it is just a shot in the dark, guesswork, yes you might get lucky but I doubt it.
  • donthaveakawman
  • Topic Author
  • Visitor
22 Mar 2013 15:41 #578175 by donthaveakawman
baldy110 wrote: Put everything back to STOCK settings and get a baseline. Do a systamatic trouble shooting and you will eventually find what is wrong. Stop doing modifications to stuff to try and fix a problem. The way you are doing it is just a shot in the dark, guesswork, yes you might get lucky but I doubt it.
No!!!
  • slayer61
  • KZR FLAG RELAY CARRIER #62
22 Mar 2013 15:50 #578177 by slayer61
Replied by slayer61 on topic touchy idle adjustment screw
:P :lol:
22 Mar 2013 16:44 #578184 by Kidkawie
Replied by Kidkawie on topic touchy idle adjustment screw
My Z1 did that.
Cured it by cleaning/lubing the spark advancer.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • donthaveakawman
  • Topic Author
  • Visitor
22 Mar 2013 17:04 #578186 by donthaveakawman
Its all electronic nowadays this younger crowd could lean a thing or two.
what is "drive by wire"?
22 Mar 2013 17:24 #578191 by Lorcan
Replied by Lorcan on topic touchy idle adjustment screw
donthaveakawman wrote: ok what should I start with? diagnosis time with don the caveman. bike runs good for a few hours then cuts out and rumbles for a while then takes off again. what do you suggest? heet? gasline antifreeze?
I suggest you sell the bike to someone who is willing to listen to good advice.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
22 Mar 2013 17:51 - 22 Mar 2013 17:52 #578196 by baldy110
OK, I quit.
Last edit: 22 Mar 2013 17:52 by baldy110.
