- Thank you received: 512
touchy idle adjustment screw
- donthaveakawman
- Visitor
- baldy110
- donthaveakawman
- Visitor
I am pretty sure with this weather it is the engine is too cold at such speeds in the cold.
I think that is also why it cuts out and putters for a while then jolts real quick like something breaks loose.
good to keep some upper cylinder lubricant in the gas as to not rev it while it is cold and bust up the piston rings.
- baldy110
You have a problem but I guess you know more than I do so you can diagnose it then fix it without any help.
- donthaveakawman
- Visitor
Attachment needlejet_2013-03-21.jpg not found
as you can see the old needlejets were sticking- see the groove.
Attachment plugfoul.jpg not found
here is the plugs I can't tell if they are fouling one way or another.
Attachment lllll018.jpg not found
- baldy110
- donthaveakawman
- Visitor
No!!!baldy110 wrote: Put everything back to STOCK settings and get a baseline. Do a systamatic trouble shooting and you will eventually find what is wrong. Stop doing modifications to stuff to try and fix a problem. The way you are doing it is just a shot in the dark, guesswork, yes you might get lucky but I doubt it.
- slayer61
- KZR FLAG RELAY CARRIER #62
- Kidkawie
- I bleed premix
- Thank you received: 245
Cured it by cleaning/lubing the spark advancer.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- donthaveakawman
- Visitor
what is "drive by wire"?
- Lorcan
- Speed Loony
- Thank you received: 59
donthaveakawman wrote: ok what should I start with? diagnosis time with don the caveman. bike runs good for a few hours then cuts out and rumbles for a while then takes off again. what do you suggest? heet? gasline antifreeze?
I suggest you sell the bike to someone who is willing to listen to good advice.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- baldy110
