- Thank you received: 13
Pilot jet change effect on mixture screw?
- Roadflyer
The bike had stock jetting of 15 pilot, 105 main and clip in the second from top (Canadian spec jetting). I put 110's in and ran the bike but have not ridden it yet. The bike ran well but the mixture screws liked to be set at 3/4 turn. I was thinking of going to 115 main, 17.5 Pilot and clip in the middle groove, How much does 1 pilot size change the mixture screw?
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
- bountyhunter
- Thank you received: 337
- baldy110
- Thank you received: 512
- Roadflyer
baldy110 wrote: With how you have yours set up, I would run the 17.5 pilots. It will start easier and idle better.
I have it back together now. It will idle smooth and steady down to about 900 rpm, the mixture screws are now at about 1 1/4 turns out. It seems to take about the right amount of time to get off the choke when warming up, so I think she's ready to ride :woohoo: I hope they clean the winter sand off the roads soon!
- morhaven
In canada as well.
- Roadflyer
morhaven wrote: Hi i got a 79 st as well. All stock but pods. Trying to figure out what jets and clip position to use. Any suggestion.
In canada as well.
- jonarmstrong
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
- baldy110
