Stage 2/3 Jetting
- freakinbike
15 Mar 2013 03:36 #577005
by freakinbike
1982 GPZ750, stock (for now..)
1973 VW Bus
Can life really get much better?
Stage 2/3 Jetting was created by freakinbike
I put Harley mufflers on my KZ750. I already need a carb rebuild, so while I'm at it, should I go with Stage 2 or 3 jetting?(also going to put on pods) Please forgive my newbieness, I'm very new to this, but not a stranger to garage work. On descriptions for both Stage 2 and 3 jet kits, they are described as for use with well designed pipes. Should I just move one step up on the jets? (the bike is running lean, but maybe the rebuild will solve that)
Thanks!
Thanks!
1973 VW Bus
- baldy110
- Thank you received: 512
15 Mar 2013 12:54 #577040
by baldy110
Replied by baldy110 on topic Stage 2/3 Jetting
It has been my experience that the "stage 2 and stage 3" jet kits are basicly the same. The only thing different you are doing on a stage 3 kit is putting in larger main jets. Larger mains will only effect the upper RPM's where you really don't spend much time at.
And now because you put a harley part on you Kawasaki it will start leaking oil and fail to start on you.
- donthaveakawman
- Visitor
15 Mar 2013 18:40 #577086
by donthaveakawman
Replied by donthaveakawman on topic Stage 2/3 Jetting
the only jet kit I know of is the dynojet and it only has the 1 and 3 stages
- Thank you received: 2829
15 Mar 2013 18:45 #577088
by 650ed
Replied by 650ed on topic Stage 2/3 Jetting
I believe your bike came with CV carbs. If so, don't destroy the airbox as you may want to go back to using it after you get tired of fiddling with the carb jetting for pods.
- donthaveakawman
- Visitor
16 Mar 2013 00:14 #577140
by donthaveakawman
yes the jets are a pain, I could mess with them for days and find out the fuel filter was the problem.
